My guess... 10mm is less than 1/2 inch. The specs just aren't accurate.
All the sites i looked at said they were almost identical. Comparitively equal on a 10" wheel they measured
325/50-15
11" tread width
13" section width
weighs 36lbs
overall diameter equal to 28"x13.50"-15
315/60-15
11" tread width
13.4" section width (due to larger sidewall)
weighs 40lbs
overall diameter equal to 30"x13.50"-15
SO... depending on what you plan to use the tire for, a taller/heavier tire could hurt quite a bit.
 Bagram AF Afghanistan
