Old 08-13-2007, 08:53 AM
cbreez cbreez is offline
after changing parts, most likely the slave, for this application use a dot 5 silicone fluid....completely drain all of the old fluid out and refill with new...with a b/draft it's easy to fill the master cylinder by putting your fluid in a shot glass or a very small jar and filling from the opposite side of the car (use a car cover), as there is not much room in that location....properly support the car with jackstands...either use a vacuum pump (if by yourself), and suck from the bleeder until nothing but fluid comes out, or have a lightweight friend get in the car and bleed the system by pumping several times, then holding down the pedal, then opening the bleeder until no air comes out...just purple fluid. Repeat as necessary!
