Thread: Sidepipe flames
Old 08-16-2007, 04:04 PM
svtcobra's Avatar
svtcobra svtcobra is offline
Cobra Make, Engine: BRA 289, Rover 4.6 V8
Originally Posted by wtm442
Absolutely safe. What's a small explosion inside of a side pipe. Absolutely safe until you blow off the side pipe. Gee, I wonder if exploding steel can go thru fiberglass?
I'm OK, because I have rear exit pipes .... so I would only get exploding steel going through the 32 gallon gas tank located under the trunk floor and directly above the exhaust mufflers
Why don't you just throw some M80 firecrackers up the side pipe and see what happens.
Now that would be childish .... wait a minute, where did I put those firecrackers left over from last New Year's Eve ??? ....
Friend of mine did the "turn key off and back on" when we were teenagers in his straight 8 Buick. Blew the entire exhaust off, ran over the mess which punctured a tire causing the car to swerve hitting a big curb and bending the rim. We fixed the problems and a week later threw a rod right thru the block! Ah, those were the days.
Oooppppssss - maybe I should consider going back to edit my "comparatively harmless" post
