Old 08-16-2007, 10:47 PM
767Jockey's Avatar
767Jockey 767Jockey is offline
Actually, there isn't anything to mock up. The small block is in the car, all the chassis mounts are standard mounts for a small block. I'm almost certain that a small block and FE use the same mounting positions on the frame. Has anyone here pulled a small block from their car, and put in an FE? If you did and used the same transmission, did the rear transmission mount line up OK? I'm pretty sure it all does, just wanted to double check for certain with someone who's done it. Anyone???
