Thread: Solid Mounts
Old 08-17-2007, 08:59 AM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
I also use solid motor mounts and a urethane trans mount. I want to eliminate driveline movement without turning the engine and trans assembly into a stressed member. The logic is that with all the flex in a Cobra chassis, a solid trans mount that's matched to solid motor mounts will place loads on the trans case that it wasn't designed to handle.
Scott
