Old 08-17-2007, 05:06 PM
MaSnaka's Avatar
MaSnaka MaSnaka is offline
Olddog, same issue with me. Same tire size, same wear pattern. When I took possesion of my car it had 15 lbs in the rear. I thought that was to compensate for the wide tread and center tread wear. I noticed the rear end seemed to shimmy at certain times. I have since raised the pressure to 25lbs, much more stable handling and 6k miles later no noticable change in wear pattern. I run 26 in the front.
John
