Old 08-18-2007, 01:24 PM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
Don't worry. Just place the flywheel on the hub and rotate until all the bolt holes line up perfectly. The bolt holes are slightly misaligned to avoid attaching the flywheel in the wrong position. It's difficult to see the misalignment by just looking at it. While I'm on a roll here, be SURE to coat the bolts with a thread sealer before screwing them in. Oil leaks can occur through unsealed threads.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
