Ready to roll what next
My B&B is complete and ready for the road, what a great feeling! While I am ready to enjoy the car safety is my foremost concern. I have taken the car out on three speperate 2 mile test runs and checked everything over upon return. I had a few fittings that needed tigtening and now see no visible leaks and no abnormal noises noises while driving. What process did you go through to ensure the car was completely road worthy? I need to have the alignment done and will continue to fine tune the coil overs for the correct ride height and handling. Everything is greased, checked lube levels, coolant topped off and engine is cooling propoerly. I still need to work on the brakes a little more to get a firmer pedal. Do you feel the pedal pump method is better or using a "one person" brake bleeder?
What other things should I be aware of? I appreciate this forum as you get advice from real owners of these great machines.
