Old 08-20-2007, 05:39 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Dean Lampe is completing his RCR GT 40 and he has place the same 9" end and re-torque everything and after he finished he would put a dab of PINK (of all colors) on each nut and bolt he checked so he would know everything had been looked at and checked.
Brakes: Are you using the cast iron Master Cylinder that came on your kit? If so you will at some point want to upgrade your brakes from the 9" rotors and GM calipers to a bigger system if you ever want to put your car on track and turn some serious times. For street driving they are great.
Bleeding method: I like the pressure bleeder or mini-vac system first and then do a two person pump and bleed before you finish up. Be sure you first bench bled your master cylinder.
Clois
"Let's roll"
"Be part of Something Good
