Tan,
If I remember correctly, the side of the Battery Brain that says "Batt 12v+" would normally be connected directly to the positive terminal of the battery, and then the positive battery cable would be connected to the other side of the Battery Brain.
I can't quite make out from the picture how yours is wired, but I think it may be backwards. To make it work (I think) you should attach the positive cable coming directly from the battery to the "Batt 12v+" side of the Battery Brain, and then attach the other side of the Battery Brain to the stud on the starter solenoid. However, I know on my car, there would be some clearance issues if I tried to mount it where you are.
I am not familiar with the SPF battery trunk mount, but is there not some room on the side of the battery or on top?
Rick
ERA 644
I'm getting old too fast and smart too slow!
