You can use a less restrictive air filter in you S&H. Some of the people here use the K&N E1015. I used the E2570 on my Classic. The 2570 is the right diameter and the height is 2.5 inches. If you want to maintain that "correct" look, use E9181. It is an almost exact replacement for original and you can use the wire mesh screen, for an even more "correct" look. There are a couple of older threads that go into this issue pretty thouroughly. K&N part number for Stellings http://www.clubcobra.com/forums/showthread.php?t=41977
"The 427 Cobra is easily the highest performance car ever sold for street use. A decent 427 - not the worst, not the best, will go from zero to 100 mph and back down again to zero in less than 14 seconds. All thing considered, you can put together a pretty good argument that the 427 Cobra is the ultimate performance car, judged on any basis you want to name." Taken from; Corvette, The Sensuous American
