Old 08-23-2007, 01:08 PM
Gatorac's Avatar
Gatorac Gatorac is offline
Cobra Make, Engine: BDR 930, 427 Windsor T56
I've been looking at that damper for over 2 years. I even went so far as to put together all of the part numbers of the joints and shafts needed to install in my car and where to but them. I'm just not convinced this will solve the problem. I believe these joints are made to absorb vibration. Not the side to side "shimmy" that I can't seem to get rid of. At times the outside edge of the steering wheel can dance back and forth 1/4". That seems more then a vibration damper would be able to dampen.
To install one you would need to ditch both existing U-joints. Replace the entier section from where it bolts to the steering column to the rack.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
