I have never noticed differential flex, but I have broken "the bolt". That was when I installed a 3.91 differential behind 436 RWHP on the track. The answer from Reg was to drill out the threads in the differential and install a grade 8 nut and bolt. Cost maybe $.075. And if you ever do brake the bolt it is a simple matter to replace it since there is no drilling out required because of the nut arrangement.
This fix has lasted me two years and many open track events and a few runs on the drag strip. When that modification was done I changed the ratio to 3.73 with three clutch packs. Lots of torque, with slicks to boot.
The brace looks great easy to install but I question its necessity in a BDR, when the bolt trick will work. Remember the E-36 BMW is a lot heaver.
JayB
Jupiter, FL
