Old 08-24-2007, 10:39 AM
Tony Aprile's Avatar
Tony Aprile Tony Aprile is offline
Cobra Make, Engine: SPF #1358 Silver/Black stripes 466 2X4
are you running he factory dual quad linkage ??? and do you have an electric choke on the front carb...if so make sure the choke isn't binding...and your accelerator is adjusted...just to make sure disconnect the accelerator linkage to the carbs to see if it will idle...at that point turn your idle mixture screws to until it stalls...most likely something is not adjusted properly.
Tony
