Old 08-24-2007, 10:07 PM
My ERA is very close to orginal specs, OEM iron heads, OEM alloy intake, flat tappet cam, top loader. The rear end ratio at 3:31 is not good for a 0-100-0 run and is higher than was typical 'back in the day'. But it will still do a hundred in 8 seconds flat. Assuming 5 seconds to stop thats 13 total, give or take a few tenths. Lower rear gear and modern sticky tires would make it even faster!
I never had an opportunity to measure the 100 to 0 time, I might try that with a passenger and stop watch just to see if 5 seconds is 'in the ball park'.
