Old 08-15-2001, 08:03 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Your local speed shop or Mr. Goodwrench dealer has a product called EOS, or GM Engine Oil Supplement. A container of this to the oil makes a good assembly and initial fire-up lube. That's all you need on the bearings and rings. Cam assembly lube from Crane, Comp, etc., are all Moly based lubes for cam and valvetrain assembly, and mix with the engine oil on fire up.
