Originally Posted by sambo
Nice pics Craig, thanks for those. At a glance my R33 Gts-t diff is pretty similar, but as we know it has a slightly wider cradle (mounting points anyway) and different drive shafts etc. Anyway I was planning to take off my discs and clean everything up on the weekend but that 36mm nut on the end of the axles put a halt to things. Now to find one on the cheap - what a P.I.T.A.
One of the first things I made after buying these rear-ends was make a plate with the stud pattern drilled in it and welded to a piece of 2x2 box section about a metre long, did the same with a 36mm socket, makes loosening/tightening that big nut a breeze. Also drilled a Holden/Vette pattern in the plate so it does double duty.
Jac Mac
