David,
Have you found any trade off or down side to shrouding the cooling fans only and not the core? Did you need to increase the fans CFM from the full shroud design fan? You mentioned the aluminum small blocks were slow to reach
oil temp with uncovered
oil coolers on street cars. Do you run
oil T-stats as standard configuration or is that more on the owners side of the coin?
Thanks for the input and lessons learned.
Jeff C
