The cable isn't a problem. You need the correct gear to go on the end of it that is inserted in the transmission. Call Standard Transmission in Dallas/Ft. Worth and they can fix you up. Need wheel height and rear gears. The Faria Speedo indicates 60 mph at 1000 rpm cable speed. I got my gear from Standard and was surprised how accurate the speedometer is. (I just didn't expect it to be right) I got my cable from Oreilly Auto.
