Haywire Wiring and B&B Car
My car came with the Haywire wiring harness assembly. Everything went fine and all works properly except the horn blows all the time with the battery connected. I have not installed the steering wheel yet on the I Did It column but can't imagine that is the problem. Literature and diagram with the fuse box indicate a horn relay but it doesn't have a horn relay I can find. One relay is the fan and I can't remember what the other one is but it isn't for the horn. I take both relays out and the horn still blows if battery connected. I will call B&B tomorrow and Haywire if necessary but wondered if you guys had a similar issue and found a fix. I didn't need to modify wiring to make things work so I am assuming I didn't screw it up installing the wiring kit. It is a 7 Fuse set up. (Yes I do disconnect the horn and it isn't sounding all the time!)
