oh dear, dont tell anyone though, you might be accused of being a whiner; let them find out for themselves
LOL on a serious note Im sorry to hear yours has gone belly up as; sometimes its just the banjo seals, so if you are resealing, get those seals as well. If the banjos are leaking it doesnt get on the clutch cover plate/friction plate unless youre very unlucky, unlike the main seals springing a leak, in which case it can soon get to the clutch. If you can work out an external solution it will be better in the long run, but I'd check for fluid in the bell housing drain hole 1st before you decide mr leaky is the culprit.
