Old 08-29-2007, 10:22 AM
Rick Parker's Avatar
If you increase either number you get more fuel expelled at "that" location, hence larger number in the bypass valve lets more fuel be expelled back into the bowl and less is forced out the squirters. A larger # on the squirters or lower # on the bypass would put a larger volume of fuel into the throttle bore.
Rick
