Once you bleed the brakes and get a firm pedal it should stay that way. It should not go soft over time. Make sure you do not have any leaks. The master cylinder must be bleed down. If you have a vacum pump hook up a temp line to each master cylinder port and pull a vacumm. You need to pull down the farthest wheel cylinder first and work you way to the wheel nearest to the master cylinder. Hope this helps.:
