Old 08-30-2007, 06:22 AM
Burgs's Avatar
Burgs Burgs is offline
Cobra Make, Engine: Hurricane 427S/C, KC/Pond aluminum 427/482 SO, TKO 600
Is the dip stick tube in the stock location, or in the canton pan?
In the stock location, I had the stick curling under and making contact with the stroker crank, popping the stick out of the tube. I moved it to the pan, and problem solved.
