it's true that reverse isn't syncro'd HOWEVER....one should NEVER have to go into 1st gear to stop a grinding into reverse....this is most likely a clutch hydraulic problem, clutch not completely disengaging, where the input shaft is still slightly turning...or a pilot bearing problem.
don't blame the transmission.
