Wrap any fuel connection in the area with a paper towel or some other absorbant paper and masking tape....including the vent tube end - lightly, fill the tank and take a little ride...check each piece of paper on your return for fuel spots and wetness... you will eliminate these areas from your search. The leak could also be under the car and splashing back to the trunk area. Split hose, filter, pump, hard line....
