Originally Posted by pgermond
You want to maintain that vent. You might check to make sure it's not plugged up. Does the tank have a sending unit mounted on top? Does it only leak/smell when the tank is filled to capacity? I used Permatex Aviation form-a-gasket on all areas of the tank and have never had an issue.
Good luck.
The tank has a sending unit on top.
The tank has an EFI pump also mounted on top.
Both are accessed through the trunk.
The only place I could smell gas fumes before installing the new carpet, was at the cap. If the trunk lid is not sealed up, could the fumes be entering this way?
