  #98 (permalink)
Old 09-03-2007, 08:21 AM
JayBar's Avatar
JayBar JayBar is offline
Cobra Make, Engine: BDR#078,408 Dart Block, TKO 600,Indigo Blue, White Stripe
Send a message via Yahoo to JayBar
I finally got under the car and took some pictures of my slave setup.
There is no bracket. It just inserts through the hole in the bell housing previously used by the clutch cable. I added a thin fiberglass spacer to give it some heat insulation. You have to extent the pull arm to reach the yoke.
Works well but like all hydraulics in the BDR it needs to be flushed out on a regular basis.
http://www.clubcobra.com/photopost/d...m/PICT4814.JPG
http://www.clubcobra.com/photopost/d...m/PICT4810.JPG
JayB
Jupiter, FL
