Thread: tilton pedals
Old 09-03-2007, 05:26 PM
ntrudelle ntrudelle is offline
Cobra Make, Engine: Most likely D&D,302 stock for now
Default tilton pedals
I sat in a cobra that had tilton pedals with hydraulic throw out bearing. I found the clutch pedal hard to depress, like doing leg press. Is it normal or is it common with hydraulic clutches. The kit i plan to buy has tilton pedals that comes with it . Is it something i'm going to have to get use to. Compare to a mustang clutch it was almost twice as hard to depress. Was it unusual or it's the way it is. I thought hydraulic set-up would be easy. Thanks !
