Old 09-03-2007, 06:55 PM
vettestr's Avatar
vettestr vettestr is offline
Cobra Make, Engine: Cobray-C3, The 60's body lines on todays chassis technology
Check your balance bar for being centered first of all (you can do the front to rear bias with an adjustable bias valve). Then make sure you are allowing the M/C piston to completely return to home. For now leave a little extra free pedal movement. Too chase problems leave a good 3/4 inch of free play on the pedal to ensure each master cylinder is returning to the home stop.
If M/C does not have enough free play it has a internal passage that never closes and no pedal pressure can be built just like problem you have now. Then re- bleed the heck out of system. good luck, it will be fine!! Jeff C
Jeff Classic
Manufacturer of the Cobray-C3
www.cobrasnvettes.com
