Cam for a Weber inducted 331
I see lots of references on this board about using a cam that is "Weber friendly". However, when looking through the Comp Cams catalog, I see lots of applications, but not one of them says anything about using an IR manifold and Weber carbs. I would like to use a solid roller, and the compression will be at 10.2 to 1. Also using Edel Vic Jr heads. Any input will be appreciated. John
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
