I had to pull the pictured pan as it would not clear the motor mounts on the frame, I went with a Canton Road Race pan and had a 12 AN fitting welded on on the rear.
I will post more pictures shortley.
The extra capacity of the pan, and the addition volume/pressure from the external pump is also welcome. I'm pulling 60lbs psi at hot idle.... 12AN lines to the
oil thermostat and 10 AN lines to the cooler.
