I just get into this posting daze and don't realize other people are posting and asking questions. I will try to answer.
FIA-ERA,
Please PM me and I will get you out your prize!
rbray,
For heating to the temperatures I am talking about to do you any good, you will have to use a precipitation hardening alloy.
CobraV8,
Chromoly steel is notoriously bad for corrosion resistance. You are correct that a standard heat treatment on heat treatable steels actually makes the steel grow in size. But, that only works on steels that are "heat treated" by quenching to keep the martensite. For example, 4340 changes from austenite to martensite at 1525-1550 degrees F. You are correct martensite takes up more volume.
Here, however, we are working with precipitation hardening stainless steels. In our case, we "only" heat it up to 900 degrees and the process actually makes our parts SMALLER--but it is actually very, very slight. We do not quench and temper with 17-4 ph. This touches on another VERY important reason to use 17-4. It is stable during heat treat. There is no quenching to cause cracks or to warp the part. Our parts come out perfectly concentric and through hardened when we are done. You pay for it initially as it is extremely expensive--the billet alone for our hubs is $235!
You gain it back when you can sleep at night knowing your parts are the best you could have possibly made.
mickmate,
If you look in the picture, the worst corrosion is actually right by the junction of the spindle to the upright. You can see a darker band there. The bearings are sealed, but that little part of the spindle is NOT. Water gets in there and the rust monster rears his ugly butt. (But not as ugly as Jamo's)
As for the color--the straw color is the color the hubs come out of the oven when they are cooled. They darken as they cool. Notice in the above picture the blue is just starting to appear on the hubs.
mylesdw,
On an original Cobra, the hub and spindle never touch as they are separated by the bearings. It is VERY true, however, that parts that touch and rub LIKE THAT DUMB BEARING SPACER must be made out of hard steel.
Dean,
I spend a lot of nights awake trying to figure out how to do this better. One ride with a professional driver on a track and your perspective changes. WOW, these cars better be put together RIGHT! At our event last Thursday, a Miller Motorsports instructor posted lap times 30 seconds faster in one of our cars than a pretty experienced (although ametuer driver) in a HIGHLY modified Ford GT. When you ride with one of those guys (or girls) you simply can't believe what the car can do. Like I said, I only see as far as I do because I stand on the shoulders of giants.
Lowell,
I am happy to share what we have learned over the years. Hopefully it will just make the entire industry better. Over the years many, many people have shared freely what they do with us. That is where I got all the information. Like my mother always said, "There'll be more for all of us if you share."
David
