  #107 (permalink)
Old 09-05-2007, 05:29 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
I don't have a macro lens on my camera and I need one!
Sorry for the blur, but the car is going together and I take the photos as I can while trying to run the business!
This is another weak link in the original 427 Street Cobra. If you look closely (and I know that is hard to do in the lousy picture) you can see the threads at the end of this Rose joint (the English rod end supplier) were relieved. Well, that was nice. BUT, they relived them with a SHARP 90 degree cutter and that was dumb.
I am sure if we were to Magnaflux this part we would find a nice crack right at the root of the threads. This rod end is only 5/8 in diameter. The original 427 Comp cars had the same 5/8 rod end--until they broke. So, all of the original 427 Comp and S/C cars were upgraded to a 3/4 rod end. That should tell you something! We change ALL 427 Street car rear upper control arms to the 3/4 rod end. A broken rod end will definitely break the bank on one of these cars! I wouldn't run a 5/8 rod end on the rear upper control arm unless you like gambling on double autopsies--one performed by me on your car and one performed by someone you probably don't know--on YOU!
