Old 09-06-2007, 04:03 PM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
There are many more variables which could cause a loose wheel rather than were the wheel originated. It is possible the safety wire could have been on the wrong direction and/or the spinner was loose or the wheel was not positioned securely when tightening the spinner. It's hard to say for certain. For alternate offset wheels the pins also need to be the correct length, not too long.
I have had Vintage wheels on and off the car for over two years and up into the 130 to 145 mph range top of 4th gear many times at track days and drag racing. I also have around 7000 miles of casual use on public roads. I install and remove my own wheels, so I'm pretty sure of the wire tie. I hate to admit it, but have once or twice done a wheel with the safety wire backwards. It's not hard to do, so you have to look twice. In my view and inspection and use of Vintage vs. SPF original I see no difference from a mechanical application and they even look cosmetically to be exactly the same.
