  #31 (permalink)
Old 09-07-2007, 01:20 PM
jetenginedoctor's Avatar
jetenginedoctor jetenginedoctor is offline
Cobra Make, Engine: FFR Roadster #5566 SBF Autronic engine management
Send a message via ICQ to jetenginedoctor Send a message via AIM to jetenginedoctor
Originally Posted by cobrarkc
Brian,
Do you think that a tunnelport can be port injected using a single plane intake manifold? Maybe if you use a split pattern injector to shoot around the pushrod tube. Have you ever heard of someone port injecting one or can it only be done tbi?
There are injectors available that have a split spray pattern, but I honestly don't think that you'd ever know the difference whether the injector had a split pattern, cone pattern, etc. A true tunnel port engine is going to have so much port volume that it's going to be a dog at low RPM anyway, your best hope is to try to put the fuel into the intake runner as close to the intake valve as possible.
BK
Brian Kennedy
BMEP Fuel & Tuning -- Dyno Dynamics USA
Austin, TX
817 719 1862
dyno@bmepfuelandtuning.com
www.thedynoforum.com
briank@dynodynamics.com
