Old 09-07-2007, 07:42 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
You can find the bottom of the lobe by marking the crank pulley when the valve is completely open IE: pushed all the way down.Then rotate the crank one full turn and you will be in exactly the right spot to set that valve.Repeat 16 times and you will be done with perfectly adjusted valves!!
