try some Water Wetter works if your not getting crazy hot or some internal problem ,it breaks the surface tension of your coolant to help it get to hot spots inside your engine better,The farmers use something similare on ther feilds to help the water soak into the ground and break up the hard pan,its called Apsa80 i used apsa in our engine works the same .I agree do the themostat to just to cover the bases..WB
