Old 09-07-2007, 10:09 PM
jmimac351's Avatar
jmimac351 jmimac351 is offline
Cobra Make, Engine: Building 289 Lemans / FFR mkIV chassis w/ Bruce Chervenak
The glasspacks are normally spot welded in and can come loose. A friend had the same problem. Try drilling a 1/8" hole into the underside of the pipe (out of view) and putting a screw into the pipe. That should snug the inner metal canister up to the sidewall and stop the rattle. Or, you could spend a lot of money to cut the pipe open, weld, coat the pipe...
