Old 09-08-2007, 06:44 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
1971boss,
If it doesn't overheat, you're ahead of the game!
The fan needs to blow through the radiator toward the rear of the car. Or pull, whichever its location demands. My main fan is a puller located right behind the radiator.
The next important item is to make certain all the air is out of the cooling system. In a lot of kit cars, this isn't easy. When I put water back into mine it usually takes some squeezing of the hoses to expel air - burp - the system, followed by several heat/cool cycles where I check and add water. The difficulty will depend on how your cooling system is physically set up.
I do have a 180 degree thermostat and a good Griffin aluminum radiator.
If you do this and still have problems, please let us know and describe the circumstances and symptoms in detail.
