|    Not Ranked
				 Calculating C/R
 Thought I would verify my C/R as I'm trying to figure out my gas needs, currently running a 50/50 blend on C113 and 93 with no issues and a nice clean burn. Would like to know my actual fuel requirement...
 Using the KB claculator I come up with a 12.30 static C/R, is this right for the following combination?
 Head Volume: 58cc (AFR205)
 Piston Volume: 5cc (JE piston 232459)
 Gasket: .039 (Felpro 1011-2)
 Bore: 4.040
 Deck Clearance: .015 (72 block with .015 decking (9.480 - .015 = 9.465)
 Stroke: 4.0
 Would like to calculate Dynamic, but I don't have the spec for intake valve closing for the Comp Cams 35-781-9
 Rod length: 6.2
 Anyone able to verify and also help with the Dynamic?
				__________________BDR 559
 Indigo Blue, White Stripes
 SBF 410
 TKO 600 .82 OD (Road Race)
 HP= Enough!!
