Old 09-14-2007, 12:46 AM
400TT's Avatar
400TT 400TT is offline
Yes, a few Cobras around with ABS and/or Traction Control.
You will need wheel speed sensors front and rear.
Then either use a factory ECU & required accessories to get it all working. Or go aftermarket ECU etc.
Our kits use either Series 1/2/3 Jag front/rear suspension. So no wheel speed sensors. Some kits use parts that make it easy to fit wheel speed sensors, well only one that I know of. Harrison Kit uses Skyline Rear and it can be found with factory wheel speed sensors and also it's front hubs/uprights are Commodore, so you can just get ABS versions and bolt it on. Then the rest of the stuff.
We built our last Cobra with TC in mind. Harrison with Skyline GTR rear and we used Skyline GTR front hubs/uprights. Used Autronic SM2 ECU.
Wheel speed sensors come in handy as you can also use them for speedo.
www.absolutepace.com
