Just wanted to re-post the information regarding the group buy I have put together. For those of you just tuning in (now that CC is back up) following are the trailer specs:
$4100
Brand NEW FRONTIER 20' x 8.5' V-Nose trailer built with the following specs:
Standard Features
8.5 X 20 Auto Carrier
6" I-Beam Frame
2-3500# Leaf Spring Axle
Drop Axles
No Show Beavertail
4-Floor mounted D-Rings
16' O.C. Crossmembers
16" O.C. Sidewalls
Brakes on Both Axles
7-Way Bargman Plug
78" Interior Height
2000# Tongue Jack
2 5/16" Coupler
24" ATP Stone Guard
36" Side Door with Camlock
Side Door Hold Back
12 Volt Dome Light
12 Volt Wall Switch
.030 Gauge Aluminum Exterior
Baked Enamel Finish
Roof Vent
Aluminum Teardrop Fenders
3/4" Exterior Grade Plywood
Floor
3/8" Premium Grade interior
walls
EZ Lube Hubs
Safety Chains
Heavy Duty Exterior Trim
ST205 15" Tires
Contemporary Style Wheels
Break Away Kit w/ Battery
Trailer comes in white, but you have the option of adding color for $75. Rear door is a HD with spring assist that is rated at 3200lbs. For those who want to add the EZ track, it is $10PLF for recessed and welded to the frame and $7PLF for surface mount.
For those wanting to add additional doors and other options that is possible as the trailers are built to our/your specifications. The Frontier trailers are built in S. GA and all shipping will be calculated from that location.
These trailers are being offered at Dealer Cost and come with a 3 year warranty. We have met the minimum volume requirement and have the LOWEST price available.
Cost is only $4100 plus tax for any Florida residents, plus shipping. Shipping to Tampa/Orlando is only $300 (which is approx $1/mile) which can be used as a comparrison to other areas. Trailer are shipped in pairs to keep the transportation cost down.
There is a $500 deposit when ordering with the balance due when the trailer is completed. I will be making the first orders on Monday which at this point is six trailers!!! and another order in approx 2 weeks after that. Lead time from the time of order is two weeks for trailer completion.
