I've seen the intake price range from a low of $900 to a high around $1,500. Of course you HAVE to run a high riser intake with high riser heads. This setup is very rare, expect to pay some big dollars for the heads, depending on condition of course.
If the DATE CODE is important then these are really cool heads/intake. If it's NOT important 'after market' intake and heads are available. Blue Thunder has a set of high riser heads that DO require some port work to match the high riser intake for 700-800 dollars. A modern high rise intake can also be had for much less dollars than a true date coded intake.
As for the motor, well it's worth whatever 427 center/top oilers are bringing these days. Plan on a complete rebuild and expect to spend 3 to 4 grand for parts alone. Considerably more if you have someone else rebuild it.
