Old 09-16-2007, 12:15 PM
jspires jspires is offline
Cobra Make, Engine: FFR, 302
Send a message via AIM to jspires Send a message via MSN to jspires Send a message via Yahoo to jspires Send a message via Skype™ to jspires
Talking Newbie from Texas - sort of
I actually joined this forum back in 2002. I think that was shortly after I bought my FFR kit from a local guy. I worked on the kit about three weeks then the car sat collectiing dust.
I just started working on the car again and I am having a ball! Pulling out my hair and trying to figure out what to pieces to buy and how to make it all go together :-)
FFR1576K is the car number if that tells you how old the kit is. I think FFR is up to the 7000's at this point.
I have had to undo some of the work the previous owner did. I think he got in a hurry. This has not been too bad since I have learned a lot more about the car but it sure makes the build longer :-)
I am going to bore out the stock 5.0L and put a bigger cam in it. I already have GT-40P heads and intakes so it will get a little bigger pop.
I have the IRS rear end but what a headache it has become. I can not even get the frame piece into the frame. I think the IRS cage is bent and it will not sit right. Still working with FFR on a solution.
There is lots to do so I suspect there will be a lot of posts and questions.
James
