The CR uses the AU falcon rear end assy.
My donor was from an XR8 and it had the abs sensor and the wiring harness supplied with the rear end.
I am sure that you could machine the inside of the jag rotor and fit a reluctor ring from the AU ford and then go with complete AU abs setup?
Cruising in 5th
