Rear brake help
Help. My rear brakes are starting to drag after about 2500 miles. I have put the car on jackstands. It requires quite a bit of effort to turn the rear tires while in neutral and has a grinding metal on metal sound. The noise seems to be symetrical side to side. After pulling the tires I noticed that the brake pads seem to be touching the rotors. There does not seem to be any fluid leaks, the brake pedal is firm and the fluid resivoir is full. Are these adjustable? Should I try braking while in reverse to help adjust? Thanks
Randy
p.s. I have to go to work now so will be unable to post thanks and response to further questions until tonight.
