Old 09-20-2007, 07:34 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
First the disc has to centralized in the caliper with the shims on the output shafts.The handbrake caliper should put the pads pretty evenly against the disc.The little U shape springs that go the handbrake calipers should be bent back to nice and straight so that when they are mounted they hold the pads just off but close the disc.The screw in the calipers that hold both together withe the splitpin should be adjusted to the same just off the disc.Then put the split pin back. Adjust the cable and then just hold the handbrake button in and pump the handle up and down a few, maybe more ,times and it should be right
