Old 09-21-2007, 05:44 AM
strictlypersonl strictlypersonl is offline
We use the spacer with some clutch combinations so you may need it.
Once the slave cylinder is mounted, you may have to trim off the threaded rod to clear the fork. The ball-end will be retained in the fork depression by the external return spring and/or the slave's internal spring.
