im coming up to qld thurs night nov 1st and coming home on mon 4th nov
ill bring up whatever i have finished if not 100% finished ill just bring it back home or finish it up there
i am in process of looking at another way to use ls1 on an l76 without having to remove crank and change reluctor wheel
it will be a kit and hope to include
mechanical parts
wiring not too much hope to just plug in
instructions
only prob is fly by wire throttle body is not changeable between ls1 and l76 as the ecu cannot work with the other throttle body due to sensors working in opposite way
so if u do change to l76 and use ls1 wiring and ecu u need to use ls1 throttle body
i think the demand might be there in afew years
so ill see how it goes
